Dabar yra 28 Bir 2026 05:19
 Pranešimo tema: 40A ESC
StandartinėParašytas: 02 Sau 2013 10:21
Pranešimai: 1192
Miestas: Visa Lietuva
Naujas 40A ESC , 50Lt. yra 2vnt.
Features :
- Safety Function : If throttle stick not at bottom while connecting battery, motor will not start
- Throttle Range Setting
- Programmable using Hobbywing Program Card or by using Throttle Stick
- Setup - Braking
- Setup - Low Voltage Cutoff Soft / Hard
- Setup - Start mode Normal / Slow / Slow
- Setup - Timing Low / Mid / High
- High Voltage Protection
- Overheat Protection
- No Signal Shut Off Protection
- English Manual is included
Specification :
- Con. Current : 40A
- Burst Current : 55A (10 Sec.)
- BEC Mode : Linear Mode, 5V@3A
- Programmable : Yes
- Battery cell : Li-PO / NiMH
- Weight 35g w/ Heat Sink
- Dimension (mm) 68 x 25 x 8
