Dabar yra 21 Spa 2026 05:22
 Pranešimo tema: micro servos 3x inolab hg-d202hb ir Hitec 3x hs-5055mg
StandartinėParašytas: 23 Vas 2012 10:20
Užsiregistravo: 11 Bir 2005 19:52
Pranešimai: 239
Miestas: Klaipeda
Tikslios skaitmeninės micro servos mažam heliui ar lėktuvui (sklandytuvui) :
puikios naudotos 3x inolab hg-d202hb, nemokamai pridėsiu dantračių komplektą (pirktos ne hobbyking'e) - trys tik už 135lt
Product description
Ino Lab Servos - Digital Precision, Blazing Speed & High Torque. Featuring ball bearings for improved function via the output shaft, and carbon gears for strength, durability & wear resistance. Digital performance at this cost doesn't get any better!
Specifications:
Operating Voltage: 4.8V Only
Test Voltage: 4.8V
Operating Speed: 0.11 sec/60 degrees
Stall Torque: 1.8Kg.cm (24.99oz. in.)
Dynamic Torque: 1.5kg.cm (20.83oz. in.)
Mhz: 333
Features:
Motor Type: Metal Brush 3 Pole Motor
Upper Ball Bearing: MR74 Ball Bearing
Gear Material: Carbon
Dimensions: 23.0x11.4x23.7 mm (0.91x0.45x0.94 in.)
Weight: 9.15g (0.32oz)
Applications:
Gliders, Park Flyers, and Micro Electric Helicopter
naudotos labai mažai- kaip naujos Hitec 3x hs-5055mg
- trys tik už 140lt
Since its introduction, the HS-55 has set the standard for affordable performance, offering precision components that have been engineered to provide long lasting trouble free service!
Enter the new HS-5055MG digital, metal geared version... with this new servo Hitec takes ultra micro performance to the next level without breaking the bank. The new HS-5055MG is a perfect choice for ¡¨ smaller¡¨ high performance electric helicopters, aircraft and sailplanes.
Detailed Specifications
Motor Type: Coreless
Bearing Type: N/A
Speed: 0.17 / 0.14 sec @ 60 deg.
Torque: 15.27 / 18.05 oz.in (4.8v/6v) 1.1 / 1.3 kg.cm
Size: 0.89" x 0.45" x 0.94" 22.80 x 11.60 x 24.00mm
Weight: 0.28oz 8.00g
Klaipėda
867642010
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
 Pranešimo tema: Re: micro servos 3x inolab hg-d202hb ir Hitec 3x hs-5055mg
StandartinėParašytas: 18 Kov 2012 14:21
Pranešimai: 239
Miestas: Klaipeda
po 130
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 06 Bal 2012 12:42
Pranešimai: 239
Miestas: Klaipeda
inolab nebėra
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
StandartinėParašytas: 07 Bal 2012 14:34
Pranešimai: 239
Miestas: Klaipeda
atskirai hitec servu nebeparduodu- rakinam.
parduodu su heliu
Blade 130x
MSH protos vbar
Trex 700e vbar
Rave ballistic vbar
Jr x11
