Dabar yra 14 Spa 2026 23:18
 Pranešimo tema: Turnigy 2 in 1 Professional Program Box for Brushless ESC
StandartinėParašytas: 02 Lap 2011 20:10
Pranešimai: 333
Miestas: Trakai - Vilnius
Kontaktai: skype rayflex , rayflex@gmail.com ,tel 868737262 arba PM
This Advanced Program Box is used to set the programmable parameters of brushless ESC, it has a 16*2 characters LCD (Liquid Crystal Display) to get a friendly user interface, so you can set the programmable parameters very easily. It is pocket-sized, so you can bring it to the racing or flying field conveniently.
This program card is suitable for the following ESCs:
EZRUN Series Car ESC (Version 2.0)
K-Force Series Helicopter/Aircraft ESC
Features:
Working as an individual device to set the ESC, the value of each parameter is displayed on its own LCD screen
Working as an USB adapter to link the ESC with a PC, and the user can update the firmware of the ESC or set the ESC by the special application software on PC.The software includes the speed calculator to measure the speed. The speed calculator only works with K-Force series.
Specifications:
Size: 90mm (L) * 51mm (W) * 17mm (H)
Weight: 84g
Input Voltage: 4.8-6V (If the ESC hasn’t a built-in BEC, you must use an additional battery pack to supply the program box)
Programmable items (Car ESC):
Running mode
Drag brake force
Low voltage cut-off threshold
Start mode
Maximum brake force
Maximum reverse force
Initial brake force
Throttle neutral range
Timing
Over heat protection
Motor rotation
Lipo cells
Programmable items (Aircraft & Helicopter ESC):
Brake setting
Battery type
Low voltage protection mode
Low voltage protection threshold
Start mode
Timing
Governor mode
Motor type
PWM frequency
Built in BEC output
Motor load
Lipo cells
Marius
JR 11X 2.4Ghz
Paskutinį kartą redagavo RAYflex 05 Lap 2011 19:28. Iš viso redaguota 1 kartą.
 Pranešimo tema: Re: TURNIGY K-Force 100A Brushless ESC + Programing Box
StandartinėParašytas: 05 Lap 2011 19:27
Pranešimai: 333
ESC parduotas liko tik programing box. Kaina 40LT
Marius
JR 11X 2.4Ghz
 Pranešimo tema: Re: Turnigy 2 in 1 Professional Program Box for Brushless ES
StandartinėParašytas: 06 Lap 2011 10:23
Užsiregistravo: 26 Gru 2008 15:58
Pranešimai: 177
ar tiks flux car sistemai?
StandartinėParašytas: 06 Lap 2011 18:04
Pranešimai: 333
Gamintojas raso kad jis palaiko tik ezrun esc
Marius
JR 11X 2.4Ghz
