Dabar yra 14 Spa 2026 12:19
 Pranešimo tema: D933MG 3x servo 450 klases sraigtasparniams
StandartinėParašytas: 30 Spa 2011 19:08
Pranešimai: 333
Miestas: Trakai - Vilnius
Nauji puikus servo varikliai su metaliniais dantraciais, gerai laiko centrus, idealiai tinka 450 klases sraigtasparniams. Isigykite situs servo varikliukus ir pamirskite plastmasiniu dantraciu keitima visiems laikams.
Parduodu 3vnt. - Kaina 100lt uz visus servo varikliukus
Specially designed for helicopter and fast response applications.Steel material used in output gear for better intensity and reduce output deviation after long time use.Its high quality motor allows longer run time on high speed.
Model: D933MG
Operating Voltage: 4.5V / 6.0V
Operating Current: 50mA / 180mA
Idle Current: 5mA
Locked Rotor Current: 600mA
Operating Speed: 0.12sec.60º/ 0.10sec.60º
Stall Torque: 1.8kg.cm / 2.0kg.cm
Weight: 12g
Dead Band: ≤3uSec
Gear: Metal
Connector wire: 210mm
Operating Temperature Range: -20°C to +60°C
Marius
JR 11X 2.4Ghz
 Pranešimo tema: Re: D933MG 3x servo 450 klases sraigtasparniams
StandartinėParašytas: 01 Lap 2011 19:18
Pranešimai: 333
Parduota
Marius
JR 11X 2.4Ghz
