Dabar yra 16 Spa 2026 06:44
 Pranešimo tema: R 35-42C 1100kv Brushless Outrunner
StandartinėParašytas: 12 Rgs 2011 09:28
Pranešimai: 1192
Miestas: Visa Lietuva
ore buvo du kartus, morkos neturejo, noriu 30 lt. Kaunas. tel.864896516
Model: TR35-42C
Input Voltage : 7.4V~14.8V (2~4S Li-po)
Kv : 1100 rpm/V within 10%
Current capacity : 45A/30s
Dimensions : 35mm X 42mm / 1.38in X 1.65in
Shaft diameter : 4mm / 0.16in
Weight : 132g
Number of poles/magnets : 14
Recommended model weight : 1000~2300g / 35~81oz
Power equivalent : .30 to .35 IC glow engine
Suggested prop size: 11x8
All Turnigy motors come with a 12 month warranty.
Suitable for the following model weights;
Trainer: 2.5kg
Warbird/Sport: 1.8kg
3D: 1.2kg
