Parduodu puiku pilnai programuojama 2.4Ghz pulta. Visiskai naujas kaina 149Lt. Galiu nusiusti ir i kitus miestus. 861220007 Vilnius
AprasymasKey Features - Model Memory - Servos NOR/REV - Steering Trim - Throttle Trim - Dual Rate - End Point - ABS Settings - EXP Settings - Trainer Port (for VRC) - CE & FCC certified
Specification - Channels : 3 Channels - Model type : car/boat - RF range : 2.40-2.48GHz - Bandwidth : 500Hz - Band : 160 - RF power : less than 20DB - 2.4G system : AFHDS - Code type : GFSK - Sensitivity : 1024 - Low voltage warning : yes(less than 9V) - DSC por t: yes(3.5mm:output:PPM) - ST range : 90 - TH range : 45(F:30;B:15) - Charger port : yes - Power : 12V DC(1.5AA* - Weight : 328g - ANT length : 26mm - Size : 159 x 99 x 315mm - Color : black - Certificate : CE,FCC
Includes : - 1 x 2.4Ghz transmitter - 1 x 2.4Ghz Receiver - 1 x Bind Plug - 1 X Manual File in a CD
| Prikabinti failai: |
flysky-fs-gt3b03-300x225.jpg [ 16.43 KiB | Peržiūrėta 977 kartus(ų) ]
Paskutinį kartą redagavo agnisimo 18 Lie 2011 17:03. Iš viso redaguota 1 kartą.
