Dabar yra 18 Spa 2026 06:43
 Pranešimo tema: FPV / adapter / V-Tail mikseris.....
StandartinėParašytas: 02 Geg 2011 18:06
Užsiregistravo: 01 Vas 2011 19:32
Pranešimai: 120
Miestas: Kėdainiai
Parduodu ,
2.4GHZ 100mW Tx/Rx & 1/3-inch CCD Camera NTSC.Kaina-200Lt
Camera spec.
CCD sensor type:1/3 color SONY CCD
Pixel;
NTSC: 510(H)*492(V) (Included)
PAL: 500(H)*582(V)
Scanning system: Interlaced scanning
Synchronization: System:Inter
Horizontal resolution: 420TV line
Minimum Illumination 0.01LUX/F1.2
DSP+CCD: CXD3142R+405AK
S/N Ratio: 48dB
Gamma Modification: 0.45
White balance: Auto
Auto backlight compensation: Auto
Lens: 3.6MM
Audio: No
Input voltage: 9~12.6V
Electric current 80MA
Electronic Shutter: 1/50 (60) ~ 1/100,000s
Video output: 1.0VP-P composite video
Operation Temp.: -20~50
Flight time: Approx 60min/100mah 3S
FPV Tx Spec.
Channel: 4-Ch, AV synchronization
Power: 100mW
Input voltage: 8~12V
Weight: 29.9g
Frequency: 2.4G 2.410G/2.430G/2.450G/2.470G
_________________________________________________________________________________________
Easycap USB Video Capture Adapter .Galite stebėti ir įrašinėti FPV skrydžius savo kompiuteryje.Galima pajungti iki 4 kamerų vienu.
Kaina-29Lt.
___________________________________________________________________________________________________________
CF2805 2840kv 29g bešepetėlinis variklis.Reike pervynioti.Kaina 8Lt(Liko tik vienas)
HXT 1700kv 16g 1700KV bešepetėlinis variklis.Reike pervynioti.Kaina 15Lt
V-Tail mikseris Delta sparnui arba lėktuvams su V formos uodega.Kaina 14Lt
Hobbywing Pentium (Professional) 10A/12A programuojamas greičio reguliatorius bešepetėliniams varikliams (Brushless ESC).Kaina 26Lt
Kontaktai-863439020;spype:nitroxi-deivis
Deividas
Tel: 860092625
Skype : nitroxi-deivis
