Dabar yra 16 Spa 2026 11:53
 Pranešimo tema: Re: 20 proc. nuolaida Blast BX RTR AKCIJA !!!!!!!!!!
StandartinėParašytas: 17 Sau 2011 16:34
Užsiregistravo: 23 Rgp 2010 10:01
Pranešimai: 57
Sveiki, parduodu LRP blast. tik 600lt.
elektronika:
Greicio reguliatorius Castle Creations Sidewinder naudotas bet puikios bukles, labai patvarus ir ne kart neapvyle tiek brushed tiek brushless varikliams, tinka tiek pazengusiems tiek patyrusiems automodeliuotojams,T jungtis, pilnai programuojamas su programavimo korta prie PC:
The Sidewinder is a perfect motor speed controller for 1/10 scale cars and trucks using a sensorless brushless motor. It is meant to be used with 540 size motors, like Feigao 540L, Castle motors or any other 36mm diameter and up to 55mm long brushless inrunner motor.
If you have a Traxxas Slash, Rustler or HPI Blitz this ESC is a perfect Tune Up upgrade for you.
With the Castle Link you can tweak all the ESC settings, including timing throttle and break.
What, s cool about it is you can still use it with your Brushed motor.
19T brushed motor limit in forward/reverse mode
No brushed motor limit in forward high power mode
5-12 cell nimh, 2-3 cell lipo compatible
Size: 1.8"x1.4" (46x35mm)
Height: 7/8" tall (22mm)
Black anodized pin heatsink
Estimated 60- 70A continuous
Kaina- 120lt ESC ir 60lt programavimo korta, perkant kartu 170lt.
Varikliai:
Labai mazai naudotas brushless 12,5T ezrun variklis su bananinemis jungtimis kaina 95lt
Valdymas:
2,4GHz Caster rissing, visos pagrindines reikalingos funkcijos.(siustuvas ir imtuvas(3kanalu)) mazai naudotas kaip naujas.kaina 140lt
Akumuliatoriai:
LIPO Zippy lighmax 5000 (2celiu 7,4v) su T jungtimi. NAUJAS kaina 110lt
Naudotas nimh 4600 enrichpower akumuliatorius, pasikrauna 4500, su T jungtimi kaina 60lt
Blasto vaziuokle, kaip nauja net protektorius ant ratu nei kiek nenusidevejas, nieks neluze ir net nepibrozdinta. Nemacius brushless varikliu tik keleta kartu vaziuota su brushed varikiu.Kaip nauja.Su kebulu ir 2vnt spoileriu. kaina 215lt
dar yra 2vnt servu:
Corona (su metaliniais dantraciais) mazai naudota, kaina 55lt
Ir stokine paparsta kaina 15lt
Miestas Vilnius
Skambinti nr. 860225019, jai nekeliu reiskias negaliu, rasikit sms atrasysiu.[b][/b]
DSC04897.JPG [ 22.43 KiB | Peržiūrėta 4201 kartus(ų) ]
DSC04896.JPG [ 140.81 KiB | Peržiūrėta 4201 kartus(ų) ]
DSC04895.JPG [ 147.94 KiB | Peržiūrėta 4201 kartus(ų) ]
DSC04894.JPG [ 149.03 KiB | Peržiūrėta 4201 kartus(ų) ]
Failo aprašymas: 12,5T ezrun variklis
DSC04893.JPG [ 51.34 KiB | Peržiūrėta 4201 kartus(ų) ]
DSC04892.JPG [ 141.43 KiB | Peržiūrėta 4201 kartus(ų) ]
DSC04891.JPG [ 142.94 KiB | Peržiūrėta 4201 kartus(ų) ]
DSC04890.JPG [ 144.33 KiB | Peržiūrėta 4201 kartus(ų) ]
DSC04889.JPG [ 66.81 KiB | Peržiūrėta 4201 kartus(ų) ]
Paskutinį kartą redagavo mirazas666 16 Rgp 2011 17:32. Iš viso redaguota 14 kartus.
 Pranešimo tema: Re: Vaziuokle, ESC, varikliai, valdymas 2,4ghz, akumai
StandartinėParašytas: 14 Lie 2011 11:07
Pranešimai: 57
pakoreguotos kainos
 Pranešimo tema: Re: Blast BX vaziuokle, ESC, varikliai, valdymas 2,4ghz, LIP
StandartinėParašytas: 20 Lie 2011 15:33
Pranešimai: 57
27T variklis parduotas
 Pranešimo tema: Re: Akcija Blast BX, ESC, varikliai, valdymas 2,4ghz,
StandartinėParašytas: 12 Rgp 2011 13:46
Pranešimai: 57
Paskutinį kartą redagavo mirazas666 16 Rgp 2011 17:28. Iš viso redaguota 1 kartą.
StandartinėParašytas: 16 Rgp 2011 17:28
Pranešimai: 57
Blastas parduodamas tik visas.Neiskomplektuojamas.
170lt
95lt
140lt
110lt
60lt
215lt
55lt
15lt
viso gaunasi : 860lt
Ir dabar viskas(Blast brushless RTR) tik uz 600lt, darau beveik 20proc. nuolaida....
StandartinėParašytas: 21 Rgp 2011 18:08
Pranešimai: 57
StandartinėParašytas: 02 Rgs 2011 08:38
Pranešimai: 57
atnaujinta
StandartinėParašytas: 08 Rgs 2011 18:25
Pranešimai: 57
PARDUOTA, rakinam
