Dabar yra 23 Bir 2026 11:07
 Pranešimo tema: Turnigy Accucel-6 50W 6A Balancer
StandartinėParašytas: 04 Spa 2010 20:30
Pranešimai: 444
sveiki pardodu sios daiktus uz juos nuoreciau gauti 130lt+siuntimas, del smulkmenu i pm.
http://www.78.lt/misc.php?showseries=MT ... OUU2Q0E%3D
Input Voltage: 11~17v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~6.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 355g
kaina bendrai yra 130 lituku + siuntimas uz jusu pinigus , pardodami daiktai yra turnigu accucel-6 pakrovejas pilnos komplektacijos nuo lcd dar net nenuimta plevele . ir pc maitblokis :)
 Pranešimo tema: Re: Turnigy Accucel-6 50W 6A Balancer
StandartinėParašytas: 05 Spa 2010 11:46
Pranešimai: 444
125+siuntimas
StandartinėParašytas: 05 Spa 2010 21:37
O krautu life a124?
StandartinėParašytas: 06 Spa 2010 06:28
Pranešimai: 444
jis krauna visu tipu akumus net masinini :)
va angliskas aprasimas:
The Turnigy Accucel 6 is an entry level balancing charger and discharger which can handle up to 6 cells and 6A.
The Accucel-6 will handle LiPo/LiFe up to 6S and NiMH/NiCd up to 15S and shows individual cell voltage during charge with realtime updates throughout the charge cycle.
Bundled with the Accucel-6 is a bunch of input and output wires which should satisfy any charging requirement.
Features;
Microprocessor controlled
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Weight: 355g
Charger is CE compliant. (See image above for directives)
This charger has a JST-XH charge plug, which makes it compatible with Zippy, HXT,TURNIGY and any pack with a JST adapter.
*This unit has the same functions (except PC-USB) and features as the iMAX B6, except that it comes with an internal cooling fan.
Note: Power supply not included.
StandartinėParašytas: 06 Spa 2010 16:56
O uz simtuka susitartume ?:)
StandartinėParašytas: 06 Spa 2010 17:41
Pranešimai: 444
rasik i pm :?
stai dar info : http://www.wgtshop.com/store/show/ACC6
StandartinėParašytas: 08 Spa 2010 10:26
Pranešimai: 444
rakinam :)
