Dabar yra 28 Rgp 2026 19:01
Naujos temos kūrimas Atsakyti į temą  [ 58 pranešimai(ų) ]  Eiti į 1, 2, 3, 4  Kitas
 Pranešimo tema: Lama v3/v4 mentės, AA akumai, takara tomy drift
StandartinėParašytas: 13 Lie 2010 22:16
Užsiregistravo: 11 Lap 2009 11:04
Pranešimai: 505
ratlankiai 26mm pločio, visiškai nauji. 30lt -> 25lt
Nissan GTR kėbulas, gale įdėtos led lempos, prieky yra reflektoriai. kaina 55lt -> 50lt.
HL lightning difo dežutė, ir pats difas, viskas ok, kaina 25lt.
onroad ralio ratai 1/10. 35lt
variklio aušintuvas 15lt
pakrovėjas, krovimo srovė 900mah, su tamiya antgaliu 35lt.
LRP AI super digital automatic ESC. Labai mažai naudotas, puikiai atlieka savo funkciją. kaina 105lt
Čia charakteristika:
Detailed Part Description:
First there were "Two-Button" setup speed controls ... Then came "Single-Button" setup ... Now, LRP introduces the new A.i. Series of fully AUTOMATIC digital speed controls. There are NO buttons to push, NO special setup sequences to run. Just plug them in and GO!
A.i. features:
Intelligent automatic setup
Forward/Brake/Reverse operation
Fail-Safe function
Integral Heatsink
Reverse Polarity, Overload, and Thermal protection
Motor and battery connectors already installed ... no soldering needed!
Rec. Motor Limit (at 6 cells-7.2V): over 13 turns
Forward/ Brake/ Reverse: yes
Voltage Input: 4-7 cells (4.8-8.4V)
Rated Current: 120A
Typical Voltage Drop at 20A (Transistors rating at 25° C junction temp.): 0.160V
BEC: 5.0V
High Frequency: yes
Fail-Safe System: yes
Multi-Protection System: yes
Connectors: Standard Tamiya style
Setup procedure: automatic (pull throttle to set up)
Cells charged: only NiCd and NiMH (LiPo cells will not work with these speed controls)
LAMA V3/V4 metal upgrade, naujas, su juo lama valdosi daug geriau, bei stabiliau. kaina 45litai.
NIMH 2000mah akumas 25lt
TT-01 tuning amortikai 30lt ir aluminis kardanas 20lt
Naujos lama v3/v4 mentys 4vnt (2A ir 2B) 5lt -> 4lt.
ratai 1/10 drift, su pvc padangom, ratlankiai balti,pvc naujos, kaina 40litų, foto greit.
Valdymo aparatūra TF3 ir rf1 su kvarcais, viskas veikia nepriekaištingai, kaina 75lt.
RTR modeliai, važiuoklės:
Takara tomy drift mazda rx7 rc, 4WD, pilnas komplektas ,trūksta tik 5 AAA akumuliatorių, 3 masina, 2 valdymas, gerai driftina, kaina
100lt -> 95lt -> 90lt -> 85lt -> 80lt.
HPI sprint 2 brushless RTR. naujas dirželis įdėtas. komplektacijoje bus ezrun 10T variklis, standartinė serva, akumas 2000mAh, pakrovėjas, tf1/rf1 valdymo apratūra, aeolian 45A esc, kaina ~540lt.
Betkurį iš savo parduodamų modelių galiu sukomplektuoti pilnai RTR, arba iškomplektuoti, su savo pasiūlymais į PM ;]
Visas prekes galima apžiūrėti Šiauliuose.
viską galiu siųsti paštu arba per autobusų siuntų skyrių visoje Lietuvoje
jei kas nors kuo nors susidomėjot, rašot PM(asmenines žinutes) arba 868919260 geriausiai sms, L-A-B-A-S tinklas. greit bus prekių papildymas [;
Paskutinį kartą redagavo planc 18 Geg 2011 20:10. Iš viso redaguota 117 kartus.
 Pranešimo tema: Re: AA akumuliatoriai, sraigtasparnio dalys, ir smulkmenos.
StandartinėParašytas: 18 Lie 2010 19:05
Pranešimai: 505
truputis dalių parduota, bet dar daug yra, nagi, perkam [;
 Pranešimo tema: Re: NITRO važiuoklė, AA akumuliatoriai, sraigtasparnio dalys
StandartinėParašytas: 19 Lie 2010 08:27
Pranešimai: 505
papildyta Nitro rs4 važiuokle
Paskutinį kartą redagavo planc 05 Vas 2011 21:55. Iš viso redaguota 1 kartą.
 Pranešimo tema: Re: NITRO važiuoklė, AA akumuliatoriai, HPI TF3.
StandartinėParašytas: 20 Lie 2010 14:04
Pranešimai: 505
Jei kažką galvojate pirkti, tik kaina per didelė, rašykit PM, susitarsim [;
StandartinėParašytas: 21 Lie 2010 12:18
Pranešimai: 505
Bump.
StandartinėParašytas: 22 Lie 2010 15:28
Pranešimai: 505
sumažintos kainos ;]
 Pranešimo tema: Re: AA akumuliatoriai, HPI TF3, TF1 valdymai, ir šiaip stuff'as
StandartinėParašytas: 24 Lie 2010 20:45
Pranešimai: 505
akumuliatorius galima naudoti siųstuve, puikiai veikia jie [;
 Pranešimo tema: Re: E firestorm 330lt.,HPI TF3, TF1 valdymai, AA akumuliatoriai
StandartinėParašytas: 25 Lie 2010 12:22
Pranešimai: 505
Pridetas nitro variklis. žmones, belenkaip reik litu, padekit :) nupirkit ka nors :)
 Pranešimo tema: Re: AA akumuliatoriai 3000mAh ,TF3, TF1 valdymai,nitro variklis
StandartinėParašytas: 26 Lie 2010 09:37
Pranešimai: 505
Lama v4 75lt.
Paskutinį kartą redagavo planc 31 Lie 2010 13:21. Iš viso redaguota 1 kartą.
StandartinėParašytas: 26 Lie 2010 10:11
Pranešimai: 1497
Miestas: panevezys
kiek nori uz lama v4 army hel isore? ir vazuokle?
StandartinėParašytas: 27 Lie 2010 09:00
Pranešimai: 505
važiuoklė 65lt.
StandartinėParašytas: 28 Lie 2010 18:25
Pranešimai: 505
yra dar viskas, kas išvardyta pirmame post'e [;
StandartinėParašytas: 29 Lie 2010 18:01
Pranešimai: 505
Bump.
StandartinėParašytas: 31 Lie 2010 13:22
Pranešimai: 505
papildyta trupučiu prekių ;]
StandartinėParašytas: 31 Lie 2010 13:53
Pranešimai: 584
Miestas: ----
namatau as kaskaipjokio nitro variklio.
dingau ;)
