Dabar yra 22 Rgs 2026 16:38
 Pranešimo tema: LRP SXX TC SPEC
StandartinėParašytas: 26 Kov 2010 09:02
Pranešimai: 575
Parduodu naudota puikiai veikianti viena is naujausiu LRP reguliatoriu. Naudotas pora menesiu, su siuo regulu uzemiau 3 ir 4 vietas stock klaseje. Jis tinkamas tiek on-road,tiek off-road modeliams,atlaiko net pacius galingiausius variklius.
Kaina 500LT derinama.
*C3 Technology: Revolutionary Copper Core Cooling technology for lowest running temperatures
*New X.Brake: Stronger brake and 10 autobrake setting for perfect adjustments.
*New ADPC 2 software: 10 power profiles, includes all profiles used by the team.
*Extra small size: 30.5x34x21mm
*Optimised Internal Temp Check System 2: Allows you to read out the maximum internal temperature that the speedo has reached.
*Sensored design
*AutoCell System: Automatic NiMH-LiPo adaptation
*Externally removable power capacitor and 3.3mm2 power cable
Motorlimit over 3.0T (7.4V)
Rec. Motorlimit Brushless over 2.5T (6.0V)
Voltage Input 4.8-7.4V
Type Forward / Brake
Hot Bodies Cyclone WCE
Hpi Baja 5b SS
Hpi Savage Flux HP
