Dabar yra 30 Rgs 2026 17:56
 Pranešimo tema: HSP 1:10 SCALE 4WD NITRO RC DRIFT RACE CAR RTR
StandartinėParašytas: 12 Kov 2010 19:09
Užsiregistravo: 08 Kov 2010 18:16
Pranešimai: 2
BEWEIK NAUJA
Trys bakai isdeginti ant laisvu,1 ramiai iswazinetas.
Yra pakaitintojas,kuro 4.5l,akumuliatoriai 1800 ir pakrowejas.
Deze,dokai.
Visko kaina 750lt
Tik masina 500lt
ARBA KEICIU I.....
Tel:+37060881510
No other car can boast the legendary performance and durability of the HSP 1/10 Chassis.
Get into serious club racing with the new Factory Built and race proven HSP Sonic Nitro. Straight out of the box this car is very competitive while the fully adjustable suspension lets you fine tune to the track specs. Mash the throttle and the new Vertex .18 screams into life with a massive 12% more power and a 9% lighter chassis, this new model is seriously competitive.
This latest model has an even lower centre of gravity and coupled to the 4 wheel drive and Ultra Low profile tyres this takes the saying of "handles like its on rails" to a whole new benchmark.
The car comes fully assembled from the factory including the latest 2 Channel Pistol Grip Radio..
As with every HSP car, we stock every spare part as well as the Factory hot up parts so you can trick the car to your specifications.
Features:
1/10 Scale Nitro 4WD Race Car
Vertex .18 Pull Start Nitro Engine
Lightweight 13.8g Flywheel
Countersunk 2.5mm 6061 Anodized Aluminium Chassis
High Flow Dual Element Air Cleaner
56mm Factory Tuned Exhaust
Adjustable Ride Height
Adjustable Down Stops Front and Rear
100% Fully Assembled
4 Wheel Drive
Front and Rear Ball Raced 5 Screw Differentials with Metal Bevel Gears
75cc Pressurised Fuel Tank
Full 4 Wheel A-Arm 100% independent Adjustable Suspension
Double Wishbones
Aluminium Cap Oil Filled Adjustable Shock Absorbers
Adjustable Height
Adjustable Toe in
Adjustable Caster
Adjustable Toe In, Toe Out
New Even Lighter Smaller Front and Gear Boxes
Ultra Low Profile Tyres
Powerful Disc Braking with Replaceable Pads
Factory Installed Servo Saver
2 Channel Pistol Grip Radio Factory Installed
