Dabar yra 22 Lie 2026 16:18
 Pranešimo tema: PARDUODU: NAUJA King Motor Baja 5b 1:5 23cc Benzinine 1000LT
StandartinėParašytas: 23 Spa 2009 10:25
Užsiregistravo: 21 Vas 2009 20:53
Pranešimai: 9
Visiskai Nauja su deze 1000lt VILNIUS 867257497. nenaudota nei karto. aprasymas cia:
The is the Elite version of the KSRC-001 Baja manufactured by King Motor Sport, which comes with the upgraded chrome chassis. This huge, fast buggy is manufactured with extreme attention to detail, and is one of the finest 1/5 scale RC vehicles on the market.
Huge 1:5 scale (32 inches long)!
Super fast (80+ KMH)! Ready-to-Run!
Double-wishbone suspension with oil-filled shocks.
Chrome-plated aluminum chassis!
Upgraded, 6,800 RPM clutch spring!
Includes FM radio, receiver & rechargeable battery pack for receiver and servos!
Features & Benefits:
23cc, 2-cycle piston-valve, air-cooled, recoil-start engine
Improved 6,800 RPM clutch spring
Upgraded, stronger gray beadlocks
FM radio helps to maximize control and range
Strong roll-cage to protect the buggy from damage in a tumble
Easy to fuel - uses 2-cycle pre-mix, 25 parts gas to 1 part oil
Drive system: Heavy-duty metal gears with sealed gear box
Gear ratio 8.4:1
Stiff, aluminum chrome-dipped chassis
Automatic, long-life clutch
Fully-adjustable oil-filled shocks to dampen any terrain
Stops quickly with the vented rear disc brake system
Sealed electronics box for use on wet days
Extra-long suspension travel: 3.75" (Front) / 3.9" (Rear)
High impact nylon bead-lock rims with replaceable tires
Paintable 4-piece body kit
Adjustable carburetor with choke and prime button
Extra hi-torque (18 kg/cm), water-resistant steering servo
Hi-torque (6 kg/cm), water-resistant throttle servo
Large fuel tank for long runs
Double-boxed to avoid damage in shipping or storage
Ready-to-Run (Just add gas, oil, & 8-AA controller batteries)
Precision manufactured for years of use and customization
Item Includes:
Fully-assembled buggy
Aerodynamic spoiler
Clear body
Sticker set
Radio controller & receiver
Tool kit
Battery charger
Receiver battery pack
Spare air-filter
Owner's manual / schematics
Whip antenna
Specifications:
Scale: 1:5
Max Speed: 80+ KMH
Vehicle size: 32" x 18" x 10"
Vehicle weight: 22 lbs.
Box: 35" x 20" x 13"
Box weight: 34 lbs.
Wheelbase: 22.4"
Tire Diameter: 6.5"
Tire Track: Front 15.6"
Tire Track: Rear 15.75"
Paskutinį kartą redagavo Soarer 05 Lap 2009 10:12. Iš viso redaguota 3 kartus.
StandartinėParašytas: 25 Spa 2009 11:05
Pranešimai: 9
StandartinėParašytas: 26 Spa 2009 11:07
Pranešimai: 9
Paskutinį kartą redagavo Soarer 05 Lap 2009 10:10. Iš viso redaguota 1 kartą.
StandartinėParašytas: 27 Spa 2009 10:59
Pranešimai: 9
Paskutinį kartą redagavo Soarer 05 Lap 2009 10:11. Iš viso redaguota 1 kartą.
StandartinėParašytas: 05 Lap 2009 10:11
Pranešimai: 9
StandartinėParašytas: 05 Lap 2009 11:40
Pranešimai: 9
