Dabar yra 16 Rgs 2026 09:15
Naujos temos kūrimas Atsakyti į temą  [ 67 pranešimai(ų) ]  Eiti į Ankstesnis  1, 2, 3, 4, 5  Kitas
 Pranešimo tema: Re: PIGIAUSIA, NAUJA, HOBBYKING VIDUJE SKELBIMO AKCIJA ;)
StandartinėParašytas: 11 Sau 2013 13:39
Pranešimai: 693
Pasipildė lėktuvų angaras atsirado :
Yak 54 30ep 1280mm (ARF)
Yak'o parametrai :
Specs:
Wingspan: 1280mm
Length: 1200mm
Wing Area: 31.2dm2
Flying Weight: 1300g
Requires:
4-6 Channel TX/RX
35mm Brushless Outrunner Motor 700~900kv
40A ESC w/BEC
4 x Digital High Torque Micro Servo
2200mAh~2650mAh 4s Lipoly Battery
Sio lektuvelio kaina 400LT YRA 1VNT
IR
Decathlon EP 48.9 inch ARF
Decathlon'o parametrai :
SPECIFICATIONS
Wingspan : 1243mm
Length : 842.5mm
Wing Area : 23.6dm2
Suggested Motor: Turnigy 28-XX size
Recomended ESC: 30A
Suggested Prop: 10x6~11x6
Weight (without motor/battery etc.): 720g
Kaina taipogi nesikandziojanti - 300LT YRA 3VNT.
SIUNTIMAS NEMOKAMAS I VILNIU IR KLAIPEDA.
skype-garson2886
tel-86penki387491
Paskutinį kartą redagavo karsonas(rcdalys.lt) 11 Sau 2013 21:43. Iš viso redaguota 1 kartą.
StandartinėParašytas: 11 Sau 2013 21:40
Pranešimai: 582
Sveiki visi. Pas Karsona atsirado labai daug nauju prekiu. Kas liecia FPV taip pat ir PILOTAZA.
PATARIU.
KAINOS MAZIAUSIOS.
StandartinėParašytas: 11 Sau 2013 21:55
Pranešimai: 693
Dar trys naujienos:
CYCLOPS STORM OSD System W/GPS Kaina 520LTL YRA 1VNT
Reliable AHRS based, don't be affected by weather and background of flying field. Fully tested with wooden, EPO, EPP and even oil-drived 15-class planes, proven robust anti-vibration algorithms. No need extra anti-vibration devices.
Tiny size with ALL-IN-ONE design, the main-board integrates OSD, Gyro sensor,accelerometer sensor, barometre sensor, and the control unit, also with enough input and output ports, offer precise attitute hold and staberlization.
Fully tested with different kinds of planes, support normal 4-channels plane, V-tail, and flyingwings.
3 flying modes, make your fly easier and funny, manual mode, PA mode, and RTH mode
3 OSD screens, you can always find your favorite one
New 10hz gps module with back-up battery, 5 seconds locking time after first locking. 100A current sensor module.
Hobbyking Katana 50ep 1500mm (ARF) YRA 1VNT kaina 620
MX2 Blue 3D 1400mm EPO žemasparnis ARTF
Pilnai surinktas ir paruoštas naudojimui modelis
Specs:
Wingspan: 1400mm
Length: 1290mm
Flying Weight: 1900g
Wing Loading: 50g/dm2
4 Channel
Komplektacija:
Motor: 36-48 Brushless Outrunner
ESC: 70A w/BEC
Servo: 2 x 9g (ST-S9G) 2 x 17g (CYS-S3001)
All Hardware
Instruction Booklet
Papildomai reikalinga:
4~6 kanalų valdymo sistema
2200mAh 4s lipo akumuliatorius
įkroviklis lipo akumuliatoriui
AA 8x baterijos
Hobbyking Katana 50ep 1500mm (ARF) YRA 1vnt kaina 560LT
Specs:
Wingspan: 1500mm
Length: 1390mm
Flying Weight: 2000g~2100g
Wing Loading: 40g~42g/dm2
Wing Area: 49.7g/dm2
Requires:
Your Own 6 Channel TX/RX
40mm Spinner
4250 Brushless Outrunner Motor
50A~70A ESC
3300mAh~4000mAh 4s Lipoly Battery
UBEC
skype-garson2886
tel-86penki387491
StandartinėParašytas: 14 Sau 2013 19:15
Pranešimai: 582
Super pardavejas. Patariu. :liux
StandartinėParašytas: 14 Sau 2013 21:29
Užsiregistravo: 02 Lap 2010 22:15
Pranešimai: 369
Miestas: Raseiniai
tikrai kad cry
RC avia modeliai
airboat
putinukas speed
1.2 Ikranas FPV
3m Ikranas FPV
TURNIGY 9x su frsky moduliu
TURNIGY accucell 6
TURNIGY accucell 8
StandartinėParašytas: 17 Sau 2013 18:23
Pranešimai: 582
Visus jau lektuvus turi LT? :)
StandartinėParašytas: 17 Sau 2013 22:07
Pranešimai: 693
Sveiki, taip visi lėktuvai gyvena jau LT.
skype-garson2886
tel-86penki387491
StandartinėParašytas: 20 Sau 2013 11:50
Pranešimai: 582
StandartinėParašytas: 21 Sau 2013 20:45
Pranešimai: 582
CYCLOPS STORM OSD System W/GPS AKCIJA Kaina 499LTL YRA 1VNT
http://www.rcdalys.lt/index.php?route=p ... t_id=11331
AKCIJA 499lt
871e52c58d298a330aa93002a206217e-400x400.jpg [ 70.39 KiB | Peržiūrėta 2967 kartus(ų) ]
StandartinėParašytas: 08 Vas 2013 21:33
Pranešimai: 582
Geriausias pardavejas.
StandartinėParašytas: 10 Vas 2013 21:21
Pranešimai: 582
Sveikas. Kada darysi uzsakyma is DE sandeliu?
StandartinėParašytas: 10 Vas 2013 21:24
Pranešimai: 693
Sveiki, šį antradieni arba trečiadienį.
skype-garson2886
tel-86penki387491
StandartinėParašytas: 18 Vas 2013 05:42
Pranešimai: 582
StandartinėParašytas: 18 Vas 2013 08:27
Užsiregistravo: 10 Lap 2012 18:27
Pranešimai: 57
Super pardavejas. Prekes gavau labai greit!!! :woww :woww :woww :woww
StandartinėParašytas: 18 Vas 2013 09:06
Užsiregistravo: 12 Rgs 2012 16:52
Pranešimai: 160
Geras pardavėjas. Geras susisiekimas ir labai greitai prekes gavau :woww
LRP S10 BLAST MT
