Dabar yra 02 Rgp 2026 03:48
 Pranešimo tema: Kas galetu patarti siais klausimais?
StandartinėParašytas: 04 Bal 2010 07:55
Pranešimai: 440
Sveiki gal galetu kas patarti kokio galingumo akumuliatoriu galeciau pritaikiti siam varikliui:T2217/7 1280KV (250W) Outrunner Brushless Motor (0.10-0.15)
£19.84
KV: 1400
Li-Poly's: 3-4 Cells
NiMH: 8-12 Cells Max Efficiency: 80%
Max Efficiency Current: 10-22A (>75%)
Current Capacity: 30A No load current: 1A
Dimensions: 27.5mm x 35mm
Shaft diameter: 3mm
Weight: 72g
Recommended model weight: 800 - 1300g
Recommended Prop: 8 x 6 ~ 10 x 5
Replacement for Park 480.
Siap esu nusiziurejes tokiu harekteristiku:
2250mAH 11.1v (20C) with balancer
£26.26
Continuous discharge: 20C (44 Amps)
*Burst: 28C (61.6 Amps)
Weight: 175 grams.
 Pranešimo tema: Re: Kas galetu patarti siais klausimais?
StandartinėParašytas: 04 Bal 2010 19:14
Tiks.
StandartinėParašytas: 04 Bal 2010 20:45
StandartinėParašytas: 05 Bal 2010 00:17
Pranešimai: 440
tai lektuvas kuri pirkau, tik pas mane vietoj 40A Brushless ESC yra 20 A nes pirkau kartu su minetu auksciau varikliu tai manau jis turi tikti. E-flite Mini FuntanaX
from E-flite
ARTF Electric Aerobatic Aircraft
Wing Span: 43 in (1092mm), Overall Length: 40.5 in (1028mm), Wing Area: 447 sq in (28.8 sq dm), Flying Weight: 27–29 oz (765–822 g)
The Mini FuntanaX is another in E-flite’s outstanding line of electric RC aircraft and accessories. E-flite uses top-quality engineering and materials in everything they make, so you always get the maximum level of value and fun. And E-flite backs all of its products with the best customer service and support in the hobby, so your electric flight experience is always a positive one.
To create the new Mini FuntanaX™ ARF, E-flite® began with the proven 3D benefits of the original Mini Funtana design. From there, they increased the wing area, added wing fillets and optional Side Force Generators, resulting in an airplane that excels in high-alpha and all-around manoeuvrability. Outfitted with an E-flite Park 480 brushless outrunner, the Mini FuntanaX is capable of superb vertical performance.
The Mini FuntanaX features:
Generous wing area for lighter wing loading—26% larger than original Mini Funtana
Tapered thickness airfoil for improved aerodynamic performance
Optional Side Force Generators (SFG's) included
Large control surfaces for precise control in high-alpha flight
Designed for use with E-flite’s Park 480 Brushless Outrunner Motor
Wing fillets
Steerable tail wheel for better ground handling
Easy-access magnetic battery hatch
Factory-painted fibreglass cowl and wheel pants
Aluminium landing gear
Assembles in just a few evenings
Balsa/light ply construction covered in genuine UltraCote
Needed to Complete (not included):
6-channel transmitter (for proper mixing and dual rate capabilities)
Micro receiver
4 sub-micro servos
Brushless Motor: Park 480 BL Outrunner or similar
40A Brushless ESC
12x6 Electric
Battery: FlightPower EVO20 11.1v 2170mAh LiPo or similar
Charger
StandartinėParašytas: 05 Bal 2010 00:40
Jei pirmam poste minėtą variklį naudosi su 20A reguliatoriumi, tai turėsi sudegusį reguliatorių. Čia reikia kokių 30A, kad ramu būtų.
StandartinėParašytas: 05 Bal 2010 12:43
StandartinėParašytas: 05 Bal 2010 13:22
Pranešimai: 440
Kaip matau kuo toliau i miska tuo daugiau medziu. as pirkau varikli kartu su greicio reguliatorium ir kazkodel jie pridejo 20A tai kaip manot ar iskarto deti ji i sona ir pirkti galingesni ar visdelto bandyti su juo skraidyti ir jeigu jis sudegs ar nieko daugiau man nesugadins? ir jeigu visdelto uzsakyti kita tai kokio galingumo iskarto imti kad nereiketu veliau vel kito ir kokios firmos tinka Spektrum imtuvui turiu omeny,kad tiktu jungtis. o del akumo kuo geriau 2 mazesnio galingumo negu vienas didelis. o sraigtus paemiau du tai : 9x6 ir10x5 tai kuri patartumet man naudoti mano atveju...
beje dekui visiem kurie nepatingejo atsakyti :)
StandartinėParašytas: 05 Bal 2010 14:47
Reguliatoriui ore sudegus gali daug kas atsitikt. Gal tik sustos variklis ir galėsi nusklęsti žemyn gražiai. Bet gal ir išvis dings valdymas. Naujas reguliatorius turėtų būti 30-40A. Jungtys iš esmės visos yra vienodos, prašaut šioje vietoje nelabai įmanoma. Du maži akūmai yra geriau dėl to, kad jie mažiau sveria. Kuo lengvesnis modelis, tuo geriau ir ilgiau jis skrenda.
StandartinėParašytas: 05 Bal 2010 16:24
Pranešimai: 440
Tai kaip suprantu juos naudoti skrydzio metu po viena ar sujungti abu i kruva?
ir dar norejau suzinoti kaip pajungti varikli prie greicio reguliatoriaus nes instrukcijos nebuvo o is reguliatoriaus iseina trys vienodos spalvos laidai o is variklio juodas,raudonas ir geltonas.
ir kuri sraigta butu man geriau naudoti 10x5 ar 9x6 turiu omeny kuo skirsis skrydzio charakteristikos naudojant viena arba kita?
StandartinėParašytas: 05 Bal 2010 17:02
Akūmus naudoti po vieną. Jei tarkim su vienu 1300mAh akūmu išskraidysi 20 minučių, tai su dviem (vieną kartą nusileidus pakeičiant akūmą) turėsi 40 min skridimo. Jei turėtum tik vieną 2600mAh akūmą, tai tiek tikrai neištemptum, nes sunkiam modeliui reikėtų daugiau gazo duoti, kad skristų.
Laidus tiesiog sujunk ir viskas, jie visi iš esmės vienodi. Variklis iš priekio žiūrint turi suktis prieš laikrodžio rodyklę. Jei sukasi pagal, tai tiesiog apkeisk vietomis bet kuriuos du iš trijų variklio laidų. Laidus patartina jungti arba sulituoti. Lituot aišku geriau, bet jei kada nors norėsi keisti variklį ar regą, tai bananai bus daug geriau.
Propelerį parinkti tai tik bandymų keliu galima. Nebent čia forume yra kas nors, kuris būtent tą variklį bandė su šiais propeleriais ir patars tiksliai.
StandartinėParašytas: 05 Bal 2010 18:30
Pranešimai: 440
Aisku dekui labai uz pagalba...
StandartinėParašytas: 06 Bal 2010 22:23
StandartinėParašytas: 06 Bal 2010 23:08
Toks pats, tik pigesnis http://bit.ly/czH6Rv
StandartinėParašytas: 08 Bal 2010 20:11
StandartinėParašytas: 08 Bal 2010 22:46
Nu jo, jie tokių nepopuliarių prekių retai pasipildo, su akūmais ir pigiais varikliais biški geriau.
