Dabar yra 02 Rgp 2026 01:26
 Pranešimo tema: cessna 182
StandartinėParašytas: 04 Lap 2009 18:45
Užsiregistravo: 04 Lap 2009 18:34
Pranešimai: 1
Miestas: SPALDING
sveiki ar apsimoka pirkti cessna 182 nauja su valdymu uz 380lt?
aprasymas tik anglu kalba.
The new Top Gun Model Cessna 182 is a true scale ready to fly 4 channel R/C aircraft.
Stunning looks make this super realistic in the air and taxying on the ground .
Months of flight testing and design yield an aircraft that is super stable and capable of maintaining flight at super slow speeds that allow novice to master flight mechanics with ease. As the novice learns he can push the Cessna 182 to faster speeds of up to 50 mph! Will easily take off from any smooth surface on its scale landing gear. Made from a high strength styro-foam for added durability.
Powered by a high power brushless motror system and a 11.1v 1650mah Lipo Battery that provide up to 13 to 20 minutes flight between for each charge.
Makes a great gift since everything needed to fly comes in one box. 4 Channel 35Mhz FM Radio, Battery, Charger, Spare Propeller, Motor all included and pre installed.
Specifications:
Length:820mm
Flying Weight:650g
Wing Span:1060mm
Flying Speed:10m/s Wing Area:17dm2
Flying Time:10 to 20 min
Wing Loading:38g/dm2
Transmitter Range; 2500 Feet Controls:. Rudder, Elevator , Throttle, Ailerons
Radio 35Mhz
kokie +/-? aciu uz ats. :)
StandartinėParašytas: 04 Lap 2009 18:56
Pranešimai: 3620
Miestas: Coventry, UK
