Dabar yra 17 Rgs 2026 18:44
 Pranešimo tema: HK450 ir HK600 dalys pigiau
StandartinėParašytas: 04 Lie 2011 17:02
Užsiregistravo: 21 Bir 2011 23:26
Pranešimai: 108
Kam reikia siu prekiu is HobbyKing su nuolaida rasyite i PM:
Lipos 7 d.
TURNIGY 5-7.5A (8~42v) HV UBEC for Lipoly
Turnigy Typhoon 450H 2218H Heli Motor 3450kv
XT150 Connectors w/ 6mm Gold Connectors (5se
Birzelio 30
TIG 62mm Carbon Fiber Tail Blade
Main Rotor Blade Assembly Tool (5mm)
HK450V2 CF horizontal/vertical tail fin
HK450V2 Swashplate
Battery Strap (5pcs/bag)
HK450V2 Carbon Fibre & Metal Tail Support Ro
HK450V2 Main Gear Set
GT450PRO Feathering Shaft (51x4mm) 2pcs
HK450 carbon tail boom
HK450V2 Main Shaft
HK450V2 Metal Landing Skid
 Pranešimo tema: Re: HK450 ir HK600 dalys pigiau
StandartinėParašytas: 04 Lie 2011 19:43
Turi buddycode? Tam yra tema i kuria suraso visi kas netingi :) viewtopic.php?f=14&t=19411
