Dabar yra 05 Rgs 2026 03:49
 Pranešimo tema: pirksiu tokia serva!!!
StandartinėParašytas: 06 Vas 2011 20:19
Pranešimai: 396
- Standard Voltage : DC5V +/- 1V
- PWM Input Range : Pulse Cycle 20+-2ms, Positive Pulse 1~2ms
- Speed : 60 degrees / 0.1s
- Torgue : > 1KG/cm (Vcc=5V)
- Max Corner : > 150 degrees
- Operation Temperature : -20 degrees ~ 70 degrees
- Weight : 7.5g
- Dimensions : 22.8 * 11.5 * 20.8mm
- Color : Black
To compare this servo with ESKY traditional servo (EK2-0500), this digital servo offers faster response time and higher speed. According to the specification, the speed of this servo(0.1s / 60degrees) is 20% faster than EK2-0500(0.12s / 60degrees).
